What pump for sprayer mod?
Old 05-04-2011, 04:47 PM
Clean94Z's Avatar
Default What pump for sprayer mod?
what are good pumps for the sprayer mods?
Old 05-04-2011, 08:03 PM
ZeeTwentyFate's Avatar
subscribed, im doing this VERY soon and need to know
Old 05-04-2011, 09:38 PM
Blwn_by_Twins's Avatar
WTH is a sprayer mod?
Old 05-04-2011, 09:51 PM
under high acceleration loads and long runs all the fluid in the T56 flows to the rear, leaving the front dry, bearings overheat and can lock up, gears heat treat and quench on decel, lots of bad things can happen depending on how long the "run dry" is. basically you spray the front portion of the T56 nearest the input shaft and the fluid restores lost lube and cooling to the dry parts...
i plan on hooking mine up to come on WOT otherwise its not needed for me, normal driving isnt a prob so no need to run spraying all the time
Old 05-04-2011, 10:55 PM
Nmbr1GMfan's Avatar
http://www.rbracing-rsr.com/oilsystems.htm
Old 05-05-2011, 11:13 AM
Clean94Z's Avatar
Old 01-06-2012, 12:56 AM
yooperLS6's Avatar
Quick Reply: What pump for sprayer mod?
