What temp is stock thermostat?
I bought my 2002 Z28 in the fall of last year. I drove it for about a month and put it in storage for the winter. Currently, it has 65K and I'm trying to get a bunch of preventive maintenance stuff out of the way.
That being said, what temp thermostat does it have from the factory? I ask this as I plan on doing a coolant flash and figure I might as well change the thermostat too. BTW Not really thinking about the 160 unit.
As a side note, I've replaced: All four rotors and pads
Installed brand new tires
Changed the motor oil to Mobil 1 0W40
Replaced Idler pulley and all belts
Had the trans fluid and filter changed
Replaced the Battery
Replaced the air filter
Changed the fuel filter
Thanks in advance!
Thanks in advance!
