which injector?
Old 05-07-2011, 12:10 PM
baggett3_27's Avatar
Default which injector?
I'm trying to decide if it will benefit me to run 42lb injectors, or if I should just stay with the stockers. It's on a stock LS1 shortblock with 799 heads milled .010 and .040 head gaskets. LS6 intake, ported TB, longtubes, UDP, MS3.
Old 05-07-2011, 12:24 PM
04gto5.7's Avatar
yes upgrade to the 36 or the 42 if u decide to stay with the stock injectors ur duty cyle will be high like 90%
Old 05-08-2011, 02:33 PM
ZL1Killa's Avatar
if you stay naturally aspirated (no boost) get the 36# injectors
if you plan or are going boosted, get the 42# injectors.
All of these ratings I'm mentioning are at the standard 3 bar 43.5psi
Old 05-09-2011, 06:25 PM
lbm13186's Avatar
^ yes go with #36 if you staying stock
Old 05-09-2011, 07:36 PM
TurboTerrorLS's Avatar
36s will do just fine for your mods
Old 05-09-2011, 08:14 PM
FICINJECTORS's Avatar
36lb 4bar will be just what you need for your setup.you have some options.we have brand new ls1 bosch.
http://www.corvetteinjectors.com/sho...?productid=322
or we can rebuild and re size your stockers for $200.
Old 05-10-2011, 12:06 AM
I'm not really looking to buy any new injectors. I was just curious as to if the 42# would be too much. I have a set laying around is why I ask.
Old 05-10-2011, 07:50 AM
you should be able to get away with a 42lb.what brand are they?
Old 05-10-2011, 09:55 AM
bridges's Avatar
Sorry to hijack your thread...
FICINJECTORS, is it possible to rebuild and resize the 42lb svo greentops to say 60 lb?
Old 05-10-2011, 10:06 AM
yes we can $200. this will also include a rebuild.fill this sheet out and send them.thanks
http://fuelinjectorconnection.com/sh...iewDoc&docId=6
Old 05-10-2011, 01:29 PM
Bosch PN 0280150558
Old 05-10-2011, 02:04 PM
Are they worth using, or should I run the stock injectors?
Old 05-10-2011, 02:25 PM
you should be fine.just make sure you get a good tune.
Old 05-13-2011, 01:38 PM
Would red top SVO 30lb injectors (F1SE-E5A) be better to run than my 42lb?
Old 05-13-2011, 09:06 PM
you will most likely have better streetability.
