being to rich on the afr hurt boost levels
Old 05-09-2011, 10:32 AM
indianakid's Avatar
Default being to rich on the afr hurt boost levels
got a novi 2000 with a 3.0 pully and a 8" balance and only making 9 psi and in some gears only 6 psi with very little belt slip if any
Old 05-09-2011, 11:41 AM
redtan's Avatar
Boost is a restriction on the intake side and it is measured by the MAP sensor in the intake manifold. Thus, the fueling you command in the combustion chamber has really nothing to do with what the MAP sensor reads in the intake manifold.
Old 05-09-2011, 02:43 PM
indianakid's Avatar
i figured this ecs kit is junk lol thanks
Old 05-12-2011, 08:02 AM
AFASTYZFR1's Avatar
How many ribs? If its making different boost in different gears it sounds like the belt is slipping.
