Jeremy Formato tuning & porting in FL & PA
LS1TECH Sponsor
Hello Guys, Just wanted to keep up a rolling contact list of people in the FL and PA areas for setting up appointments.
In FL we reside in the TAMPA area and can setup appointments here for installs, street and dyno tuning, and porting services. We also travel to shops in Gainesville, Orlando, Ftmyers, Ft. Lauderdale area (Davie), and Miami in about every 3-4week cycles.
For PA we work in Gettysburg as it is a good central local and we make about 5-6 trips a year when the weather is good. Next trip in in the begining of June and then in August.
We do require $100 deposits to reserve a spot.
If you would like to hear more about us and our work please research us under Fasterproms or Jeremy Formato . We have many prior threads that show our porting results and dyno tuning. We also have many videos on youtube.com we have a playlist under "dyno and car vids" if you scroll down the page searching fasterproms.
The shop number is 813-476-7364.
Thank you for reading.
Jeremy Formato
Jeremy Formato
LS1TECH Sponsor
Thanks everyone!
We do not recommend porting the LS6 Intake. The LS6 does not have the extra material that you see in the LS2/3/7 and you really will not see any gains from porting. If it is in bad shape, we can clean it up for you though.
LS1TECH Sponsor
Jeremy was just there a couple of weeks ago. He can only go to the shop out there every 3-4 months. If you can come to Tampa, we are just about an hour and 15min from Orlando, that would be best.
Thank you
Shalane Formato
Thank you
Shalane Formato
