speartech wiring help!!
Old 05-12-2011, 11:56 PM
Roast!'s Avatar
Default speartech wiring help!!
lost the labels on a few small wires< orange&black, yellow, purple, and green,all wires are bundled with the tach wire if that helps!
Old 05-13-2011, 12:25 AM
Roast!'s Avatar
Default speartech
is the white tach output or input? and where does it go.
Old 05-13-2011, 10:05 AM
Stu Cool's Avatar
Best suggestion is to call or email John. No one knows better than him and he is great at helping.
Pat
Old 05-13-2011, 10:13 AM
98SuperchargedLs1's Avatar
i agree call him..
Old 05-13-2011, 10:34 AM
lt4malibu's Avatar
Orange/black - Park - neutral signal to PCM
yellow - speed sensor signal for electric speedometer
purple - for TCC engagement (there should also be a pink wire with it)
green - primary cooling fan relay control
id call john to make sure but these are all off the sheet i just got with my LS1/4l60e harness from him
Old 05-13-2011, 12:54 PM
Roast1's Avatar
Thanks lt4malibu, that sounds about right, but where do I connect orange and black wire on the park/n switch? There are five wires at the
Switch. Would any of these wires keep the motor from starting?
Old 05-14-2011, 10:34 PM
lt4malibu's Avatar
you dont necessarily need it, its to bump up the idle when the car is in gear. none of them should keep it from starting. id check simple stuff like powers and grounds first. make sure the switched 12v source has 12v or better WHILE cranking. alot of the accessories drop out when cranking. also has the PCM had the VATS/theft deterrent deleted?
Old 05-15-2011, 03:50 PM
Roast!'s Avatar
not sure about the VATS, it has some sort of three wire diode connected, im getting spark while cranking, how do i test if the injectors are working.
Quick Reply: speartech wiring help!!
