Alternator and Starter wiring help...LS1
What do I need to do to wire my ls1 alternator and starter so they will work? I know its a blunt question but I need help. The rest of the wiring is already done; this is just the last thing I need to do before it runs. Its in a '95 240sx
You need the plug that goes to the alternator , and the Wire that goes to your battery . That is the nut on the back. You can either run it to your starter terminal which your positive wire connects to , or you can run it to the battery. The S terminal on the starter gets 12v when you crank the key. Find the wire that went to your old starter ,and your in business.
