what else to order with bbks
Old 05-21-2011, 09:10 PM
inssanity21's Avatar
Default what else to order with bbks
i just placed an order for some bbk lts and y. it says it comes with some gaskets. my question is are they good enough to use or should i get something different. i am debating the motor mounts still. my spark plugs are basically new and i already have the air system out and tuned. i want to be able to take off the stock stuff and put these on in one afternoon so what else should i be ordering like o2 extentions clamps etc etc.
Thanks
Old 05-21-2011, 09:23 PM
00silver6's Avatar
i got the stock gaskets when i did mine i dont know what gasket's come with bbk's I also got the corvette o2's and installed those while i was at it
Old 05-21-2011, 09:25 PM
00silver6's Avatar
are you an m6? dont forget to make sure your clutch line is away from the header
Old 05-21-2011, 10:31 PM
yep got an m6, ill make sure to watch for it. thanks
Old 05-21-2011, 10:46 PM
TImmy_Jones's Avatar
Motor mounts, O2 extensions, new plug wires (why not)
Old 05-22-2011, 11:22 AM
TransAm_VS_VR-4's Avatar
https://ls1tech.com/forums/generatio...vette-o2s.html
Just get stock o2s and change your wires at the PCM.
