1998 SS wierd PS leak into coolant?
Old 05-22-2011, 01:30 PM
crowbarmaster's Avatar
Default 1998 SS wierd PS leak into coolant?
Hello folks, just got my 4th gen last week. checked everything before I bought it. Today I went out to start it and the battery was dead. This was my own doing after noticing i left my speaker project plugged in so while it was charging up, i checked everything and wtf, there is oil in my coolant?! after picking some out with my fingers, I revieled it was power steering by the pinkish white color and smell. its a six speed car, so no trans fluid to radiator. does the PS run through the radiator? anyone ever seen this before?
Old 05-22-2011, 02:01 PM
Marc 85Z28's Avatar
The power steering fluid doesn't run through the radiator. Instead, it runs through a cooler in the upper radiator hose (which should have been extremely obvious). It's probably leaking, which is very common. The cooler was an option.
Old 05-22-2011, 05:02 PM
sjsingle1's Avatar
*did not get the memo*.............get rid of that cooler
Old 05-22-2011, 05:04 PM
Ruthless909's Avatar
^^^Couldn't have said it better myself.
Power steering cooler was an option only for SS's, right?
Old 05-22-2011, 05:41 PM
LS6427's Avatar
Here ya go: Get it done.
https://ls1tech.com/forums/general-m...cooler+success
Old 05-23-2011, 05:28 AM
The Scammer Hammer
dr_whigham's Avatar
Get it done, as in NOW! Seriously, that **** almost killed my PS pump and more than likely contributed to the demise of my waterpump. Read..... you'll see.
Old 05-23-2011, 08:08 AM
Save the manuals!
wssix99's Avatar
The cooler was originally a WS6 and SS but went on all the cars starting in 1999. (If I recall correctly.)
