Gears & Axles - Any step by step threads on gear installation?
MAROBOY_TRAV
05-22-2011, 06:43 PM
I've searched but can't really get exact details.. Any one know of any? Maybe even sites?
99ws6ls1
05-22-2011, 07:34 PM
hey i found this....
you really gotta know what to do and what to look for when your setting it up. one wrong thing and it was make some pretty obnoxious sounds. your gonna need a dial indicator to start as well
http://www.richmondgear.com/01instructions.html
djfury05
05-23-2011, 07:27 PM
If you haven't ever done it before the first step is to take it to a professional.. the second step is to pick it up when its done.. good luck
riceburnerZ28
05-23-2011, 07:33 PM
http://www.keliente.com/gears1.htm
studderin
05-23-2011, 07:55 PM
what rear end?
I just did a set in my S60 and posted a tread in there "hows my pattern look" and I linked some writes up and servise manuals for a dana60.
Check pirate4x4 there lots of good tech arctics on rear ends there. And goggle a service manual for the rearend you have.
therealcreeper
05-23-2011, 08:00 PM
I have a spare 10 bolt in my garage with way too much play between the ring & pinion to put back in a car so I may pick up a set of used gears and try throwing them in myself
SS SLP2
05-24-2011, 11:26 PM
worked great for me
Johnny
01ssreda4
05-25-2011, 12:35 AM
http://www.vernco.com/RearAxle5/index.htm
guppymech
05-26-2011, 03:05 PM
I built up a spare and I think it's a great way to do it, there's no stress about the car being down and the rear is alot easier to work on out of the car. I found this install manual from Yukon to be very helpful:
http://pirate4x4.com/tech//billavista/PDFs/Yukon%20Gear%20Ring%20and%20Pinion%20installation% 20instructions.pdf
Also this info from Randy's ring and pinion is Good.
http://www.ringpinion.com/ContentFrame.aspx?FilePath=Content%2fParts%2fRingA ndPinions%2f%2fFour_Critical_Ring_%26_Pinion_Setti ngs.inc
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
