LOTS of HP E85....What fuel Rails???
Need help with my fuel rails, will be atlease 1400hp on E85. I need a rail that will support a lot of HP and still work with my Vic Jr Intake manifold... HELP
I think any of the aftermarket rails should be able to support 700hp each. Your biggest concern is going to be feeding them. You should do -10 from the tank, split to -8's then feed each rail seperately, then run both rails to your regulator, then back to the tank. I think all of the aftermarket rails will support a -8 feed
