94 z28 driverside valve help!!
Old 05-27-2011, 06:05 PM
bizerk1's Avatar
Default 94 z28 driverside valve help!!
So I know I need to get the hayes book for the car, but Im tryin to get the valve cover off the driver side but I have the stupid air valve pipe coming from the exhaust manifold blocking it, I sprayed the bolt with wd-40 and tried taking it off with wrench it does not want to budge how did you guys get it off ? Im wanting to do this asap because I bought new 2 stock rocker arms and 2 pushrod for the one cylinder that went bad until I get those funds soon to do them all. I need to make sure that the ones in there are at least 1.5 and not aftermarket b.c It has a cam but Im not sure what one and what else did the older dumbass owner did. HELP PLEASE!
I want to get on the road soon
ohh I would have to take back the stock ones if there aftermarket before reciept exchange ends
Old 05-27-2011, 07:11 PM
bizerk1's Avatar
Need help?TTT
Old 05-27-2011, 07:19 PM
riceburnerZ28's Avatar
I used a pair of locking pliers. You could twist the top part out the way.
Old 05-27-2011, 07:46 PM
bizerk1's Avatar
Ill have to try that
Old 05-27-2011, 08:02 PM
2manycamaros's Avatar
i just bent mine out of the way also
Old 05-27-2011, 08:03 PM
5_LTR_ETR's Avatar
i broke a wrench trying to get the passenger side. so i got a better wrench and put a sipe or (sype?) on it and got my 300lb cousin to give'r a pull.. came right out
Old 05-28-2011, 01:53 AM
bizerk1's Avatar
I tried the vicegrip didnt work due to clearence i think ill just bend it, at least try nothing bad will happen fom that?
Old 05-28-2011, 02:13 PM
leadfoot4's Avatar
Can you get an open end wrench on it, or is the "hex" in the wrong orientation for you to get on it? IIRC, it's a 1" hex, and I've used a "crowsfoot" wrench, a 4" extension, and a breaker bar to get mine loose.....
One more thing...warm the nut with a torch.
Old 05-28-2011, 02:58 PM
bizerk1's Avatar
if I had a torch, here is pic
Old 05-28-2011, 03:03 PM
ZFreie's Avatar
Have you tried PB Blast? Stuff is amazing.
And for a last ditch effort...
You can invest in an "equalizer"... a 4 foot metal bar that will slip over a wrench. I cant tell you how many times its leveled the playing field against stuck and rusted bolts...
Old 05-28-2011, 04:21 PM
i had the same deal happen about 2 weeks ago, i heated it....nothing, penetrating fluid......nothing, put a big azz bar and wrench on it.....the top of that fitting is now no longer hex, its an oblonged hex lol. i bent it back out of the way. you dont need much just watch it and stop if it starts to kink or anything. after 2 days i decided to take the dang thing off and just pinched the bottom and cut it off then welded it shut.
Old 05-28-2011, 07:51 PM
bizerk1's Avatar
what did u use to bend it, this thing is pissing me off
Old 05-29-2011, 07:37 AM
leadfoot4's Avatar
In the picture you've posted, your set-up looks a little different than mine. Yours looks like the nut is a male thread, which threads down into the manifold, and the tube is held in by compression. On my '96, the nut is a female thread, which locks down over a taper on the manifold.
If yours is indeed a male thread, try this. Start the car and get the manifold heated up. Take an old candle, and hold it up against the nut, allowing some of the wax to melt and flow into the threads. Remove the nut....
Old 05-30-2011, 03:10 AM
bizerk1's Avatar
that sounds crazy but would possibly work for some reason
Old 05-30-2011, 07:23 AM
leadfoot4's Avatar
Believe me, it works!
Quick Reply: 94 z28 driverside valve help!!
