Cutlass Lsx conversion power steering help?
Old 05-28-2011, 07:55 AM
martell's Avatar
Default Cutlass Lsx conversion power steering help?
I have a 72 cutlass with factory steering box, how do you go by connecting the ls1 power steering pump to the cutlass steering box. Do i need to get new line and connections or are there a way to convert the ls1 connection to the 72 connection? Thanks
Old 05-28-2011, 08:32 AM
Old School Heavy
speedtigger's Avatar
I had a new high pressure line made at the local hydraulic shop. It was $65.
Old 05-28-2011, 09:03 AM
garys 68's Avatar
Cut the inverted flair end off your old cutlass hose. Cut the O ring fitting off the LS PS hose. Put the inverted flair fitting on the cutoff metal end of the LS hose and double flair it.
Or
Remove the output fitting and spring from the cutlass pump, and screw it into the LS pump, reuse the hi pressure cutlass hose.
Old 05-28-2011, 09:27 AM
Old School Heavy
Or
NOTE: You better have a bad *** double flaring tool to flare that high pressure line. It is some thick stuff.
Old 05-29-2011, 08:11 AM
garys 68's Avatar
Very true, but mine didn't leak. I swaped it out when I changed to the jeep steering box, so I think I've still got the old one. It's set up for the truck accessories, but it's free to a good home if anyone needs it.
Old 05-29-2011, 04:25 PM
martell's Avatar
Thanks guys I found this shop that makes lines so I'm going t have them made. I hope I can stay around $40.00 for the both of them.
Quick Reply: Cutlass Lsx conversion power steering help?
