Who all has A/C in their conversions
Old 05-12-2011, 08:32 AM
94formulabird's Avatar
Default Who all has A/C in their conversions
Who all has done A/C in thier 1st gen conversions. Ive been searching around, and Ive been maybe 1 or 2 people but there was no threads on thier process of doing it. Im interested on how difficult it was to retro fit A/C after thier swap is done. Appreciate it!
Old 05-12-2011, 09:00 AM
LSCha0s's Avatar
Subscribed
Old 05-12-2011, 09:12 AM
ls1nova71's Avatar
Depends on if you want to keep the factory A/C or go aftermarket. I've put Vintage Air on a couple, and it's not too difficult, and I've kept the factory A/C on a couple which I like better, but aftermarket is usually easier.
Old 05-12-2011, 11:18 AM
Aftermarket probably. Im just doing all my research and reading before i go diving into anything. I hadnt seen alot about guys doing a/c, so I thought I would post it up
Old 05-12-2011, 11:19 AM
****, I see your in Indep...where Im from. Pm coming your way!
Old 05-12-2011, 11:48 AM
hifi875's Avatar
wouldn't even think about not putting a/c on. I run the vette serp system w/ v.a. brakcet and sanden compressor. works great and more importantly, you can't see it.
Attached Thumbnails Who all has A/C in their conversions-camaro-ls-pics-008.jpg
Old 05-12-2011, 01:43 PM
bczee's Avatar
I was able to keep my OEM AC unit on my Chevelle with only switching the compressor for the LS1 compressor. While it may not be the greatest setup, it works and it does get the blowing air down into the high 40's...
Old 05-12-2011, 08:59 PM
wantsum410's Avatar
The last major coversion setup I did in my shop we used the Vintage setup for the '69 with all electric servo motors .If you did your swap you can do the a/c setup !I would use the Vintage new controls & avoid any problems .If you have a good a/c line man you can bring the lines out behind the fender well & not even see the bulk head with just a short line up front to comp, ect.Be sure to place the unit in the middle under the dash & take your time.If you want I will pm you the link to the build pics so you can see the line layout ect.
Old 05-12-2011, 09:23 PM
reedld's Avatar
I'm working on a vintage air install in my second gen. I am documenting and taking pics.. I will post when I get a little farther along.
Old 05-12-2011, 10:09 PM
Sunkistcamaro's Avatar
im in the process of installing a 04 GTO A/C unit in my 69 Camaro.
Its not done yet but is easy because Im also installing the GTO's dash.
Old 05-12-2011, 10:59 PM
John McGraw's Avatar
Vintage Air in all 3 of my conversions and am happy with all 3.That being said, the new gen units with electric servos like I used in my Chevelle, are way better them my old cable operated units.
Regards, John McGraw
Old 05-13-2011, 01:17 PM
c6matt's Avatar
this is on my list for next winter..
Old 05-13-2011, 03:24 PM
Ravenous T\A's Avatar
Lookin at a VA kit aswell, anybody use the Old Air kits? I know they are local around here (DFW).
Old 05-13-2011, 06:23 PM
Awesome. Thanks for all the replys guys. Im researching alot into doing a swap so i want to get it all worked out before i start buying things. Would love to see some build sheets/pictures/etc
Old 05-26-2011, 02:50 PM
sikbrik's Avatar
I'd love to see some custom hoses/routing in this thread and maybe even part numbers! I'm swapping into a Volvo and need the GM fittings for the LS1 compressor - going to leave the rest of my A/C system stock Volvo stuff. I figure a few hoses with the GM fittings on one end and my Volvo fittings on the other will do the trick without messing with anything else (obviously changing the connector for the A/C clutch, but otherwise...)
Old 05-26-2011, 03:21 PM
garys 68's Avatar
I've done the VA Gen IV setup on my 68 corvette swap. Works great, great people to deal with, swapped out the SBC parts for LS. Terrific customer support. Only downside is a couple hundred more than other kits and expensive shippping on small parts so order that stuff through a local distributor.
I used Classic Auto Air universal kit in my 72 Olds 442 LS swap since no one made a direct fit kit. Great product, price, customer service, they even have a half price deal on the Kwik bracket when you order the kit! I was able to use my 442 controls with slight mods. Only downside is it's not quite as hi tech as VA and doesnt separate the heater from the defrost vents.
Old 05-27-2011, 05:59 PM
Clyde65's Avatar
I have the Old Air with the LS compressor, works like a champ.
Old 05-27-2011, 09:53 PM
89 formula350's Avatar
ls1 compressor with the rest of the system thirdgen F-body works great. used a 90 grand am pressure sensor in place of the high side 3rd gen switch
Old 05-28-2011, 10:02 PM
Hodge's Avatar
Did you buy the setup for you 68 vette directly from VA? I am about to begin on a LS swap on my 73 Shark. I've decided to pull the factory A/C and replace with a VA setup too.
Old 05-29-2011, 04:05 AM
garys 68's Avatar
I bought through a local dealer since they had most of the stuff in stock. That way I could see if it would work on a custom install. Be sure to have them swap out the binary switch for a trinary to control an electric fan.
