Pontiac Firebird 1967-2002 - 99 ws6 power steering fluid mixing with radiator coolant
WSSICK99
05-30-2011, 02:00 PM
problem with power steering fludi mixing with my coolant any way to fix this happen twice now before it was like a check valve in the coolant tubing.. im lost anyway to by pass or fix for good help please.
Titanws6
05-30-2011, 04:44 PM
The power steering cooler pipe is going bad, you'll need to replace it. This piece, mine went bad, was doiong the same thing
Bluestreak
05-30-2011, 05:00 PM
Mine has the same problem... I just found coolant in the PS reservoir. I shudder to think what the stock PS cooler costs... I can't find it online for sale, but I haven't looked too hard either.
I'm moving to this setup (http://www.ls1tech.com/forums/12750800-post4.html). It's simple, can't cause cross-contamination ever again, and it just makes so much more sense. Why use 190° coolant to cool the PS fluid when a simple setup like this can use 90° ambient air temps? That's 100° of additional cooling! That seems significant to me. I'm going with a slightly larger fluid cooler from a website that shall remain nameless as I don't think they're a sponsor.
-R
WSSICK99
05-30-2011, 09:24 PM
o ok thanks guys so much..... much needed info appreciate A lot.
WSSICK99
05-30-2011, 09:32 PM
hey do you kno what this peace is called
20TA02
05-30-2011, 09:33 PM
-R
i have that set up and it does the job... it works good.
20TA02
05-30-2011, 09:40 PM
step by step instructions.
http://www.noid.org/pscooler/
WSSICK99
05-31-2011, 12:53 AM
o ok awesome i need to get on that shits annoying
