rear exhuast leak at manifold gasket help
I recently found out I'm leaking exhaust pretty bad at the rear exhaust manifold gasket. I've talked to a couple shops (not the stealership) and one shop particular said to ask if the front motor mount is removed can it be rocked foreward enough to get at it to repair it. Any help or thoughts would be appreciated : -)
