Pontiac GTO 2004-2006 The Modern Goat
diablo tuner not reading
Old 06-02-2011, 03:59 PM
Roman nj.'s Avatar
Default diablo tuner not reading
Can anyone help? I was doing a live data log when i turned on my ac. The diablo screen went dark and the dash beeped with service engine soon and fuel gauge malfunction, almost like it does when writing a tune on it. I unplugged it and shut off car replugged it in and when it prompts me to turn ignition key to on position it doesn't read that its on. I cant look at trouble codes, live data or modify tune now. Did i screw up the tuner by turning the ac on or can it be reset some how or ,ughh, mess up my computer?
Old 06-03-2011, 04:32 PM
DirtyDirk's Avatar
Check your ecm fuses. Have that issue sometimes with tech 2. Usually blown fuse not powering up the proper pin.
Old 07-06-2011, 06:27 PM
Roman nj.'s Avatar
where are the ecm fuses located? I checked under the steering wheel and under hood on the fender. none are listed as ecm.
