Torque Arm and a TH350
Old 06-05-2011, 12:55 PM
Restricted User
Zero4488's Avatar
Default Torque Arm and a TH350
So whats the easiest way to mount the factory torque arm one you swap to a TH350?
Old 06-05-2011, 04:11 PM
3rdgen92maro's Avatar
When I put the th350 into my firebird I used the BMR trans crossmember with the torque arm relocation bracket...it came with a poly tq arm bushing to.
Old 06-06-2011, 02:10 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I've used this when I first converted my car and didn't have any issues. It says it's for a third gen but it works on fourth gens too
http://www.jegs.com/i/B-M/130/30299/...oductId=748060
Old 06-08-2011, 01:56 PM
Restricted User
Zero4488's Avatar
Is that piece for the trans mount or the torque arm?
Old 06-08-2011, 08:14 PM
Z28/2002's Avatar
It locates the bracket for the torque arm to the tailshaft of the TH350. It uses three of the bolts on the tailshaft. I reused the stock torque arm bushing and half clamp
Old 06-09-2011, 08:24 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
The best way to mount a torque arm when using a TH350 is to definitely mount it to a torque arm relocation crossmember like our TCC009. It will give you a solid mount for the torque arm and also gives you the ability to change the instant center of the car which will help fine tune your launches and help with consistency. Here is a picture of the BMR torque arm relocation crossmember.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 06-09-2011, 12:04 PM
Restricted User
Zero4488's Avatar
Thanks....but I'd rather spend 100 rather than 200+....not building a killer just a little street car....
Quick Reply: Torque Arm and a TH350
