what are you using to install carrier pinion bearings
Old 06-05-2011, 07:06 PM
vbls's Avatar
Default what are you using to install carrier pinion bearings
i am about to do my own gears and i am getting a bearing puller, and race driver set.. but whats everybody using to install the bearings on the carrier and pinion?? i searched and read about using a pipe. what kind of pipe and where would i get that??
Old 06-05-2011, 07:09 PM
cantfind2nd's Avatar
heat the bearings in the oven at 200 degrees for a few minutes. thick walled pipe the same or close to the same size as the inner steal ring of the bearing... not the cage!
Old 06-05-2011, 07:39 PM
01ssreda4's Avatar
Press and a length of pipe thats the right size.
Old 06-06-2011, 06:48 PM
vbls's Avatar
a steel pipe??? a pipe made of what? i dont want to mess the bearings up? whats the best way to remove them
Old 06-06-2011, 06:55 PM
studderin's Avatar
press, and what every fit to do it. pipe, other bearing race....
