Used fast 78mm intake manifold good deal?
Old 06-07-2011, 10:50 AM
QIK E's Avatar
Default Used fast 78mm intake manifold good deal?
I found a used intake manifold for $400 and the guy said he would put it on for me.
Is this a good deal? I'm not looking for going more than heads and cam, so I don't think i'll need any bigger than 78mm. Just need to get a price reference. Can't find any on ebay or in the classifieds
Old 06-07-2011, 10:56 AM
R6cowboy's Avatar
If its in good condition that is a fair deal IMO.
I'd give $400 for a good used FAST 78mm.
Old 06-07-2011, 11:11 AM
QIK E's Avatar
00 car btw so it's replacing an ls1 not ls6 intake manifold.....thanks for the input. He said he'd help swap it out and i'm kind of a newbie so I thought it wasn't too bad
Old 06-07-2011, 11:22 AM
QIK E's Avatar
Would I need different coolant lines? I know I would for a ls6 swap, but what about a FAST?
Old 06-07-2011, 05:47 PM
garygnu's Avatar
you can carefully tap the stock coolant lines down to fit the fast intake.you will need the low profile button head bolts for the valley cover plate.use your stock ls1 intake bolts,I hear they don't loosen up .
Old 06-07-2011, 09:40 PM
2000_TA's Avatar
you will need a new coolant pipe and two block off plugs for the rear, also will have to either drill out the manifold for your EGR or just take it out completly i didnt like the idea of drilling out my 102 i just installed so i bought headers and deleted my EGR and AIR pump also like the idea of adding a catch can for my pcv to reduce oil into the manifold.
Old 06-07-2011, 10:53 PM
garygnu's Avatar
you can retain your stock ls1 coolant tubes.just use a plastic hammer and a piece of pine wood to tap down the coolant tubes.you want them laying flush on top of the valley cover plate.you need the button head bolts!
Old 06-07-2011, 11:23 PM
QIK E's Avatar
Is there a recent thread for this swap. I can't find a.y with pictures.
Also I don't plan on using EGR or AIR after the intake manifold swap because we'll be doing headers at the same time
Old 06-07-2011, 11:36 PM
z28MP's Avatar
I thought I saw a 90 on here the other day going a little above that price. Not really sure because I'm not in the market for one, so I wasn't paying complete attention to it just noticed the price and thought it was pretty low.
Old 06-08-2011, 01:27 AM
98z8uup's Avatar
I think 400 is a good price for it.
Old 06-08-2011, 01:47 AM
jc98ss's Avatar
i'd buy it, especially since you still have an LS1 intake on.....
Old 06-08-2011, 01:07 PM
180ls1's Avatar
id get it for sure considering a ls6 intake will cost you 300 and then you still have to install it and it should be worth another 5-10 rwhp over the ls6.
Old 06-08-2011, 03:50 PM
QIK E's Avatar
Well this guy also has a ls6 intake he'd sale and put on for 350...he also said when he dynoed his car, the intake manifolds made no difference on his car.
Old 06-08-2011, 06:55 PM
reeperz28's Avatar
The fast in the looks department are def cooler . My opinion is get the fast and get it ported by some of the dealers on here and get better gains . Ls6 typical gains are max 15 hp low 13hp but ported should get north of 18 . Worth it in my opinion .
Old 06-08-2011, 06:58 PM
MonmouthCtyLS7's Avatar
For the piece plus an install definitely...id check and see if it was ported yet, if not id have that done first.
Old 06-08-2011, 10:13 PM
Mike Morris's Avatar
Port that bad boy before installing!!
Nice deal btw
Quick Reply: Used fast 78mm intake manifold good deal?
