Iron block
Iron block
For those of you with iron blocks living in the southern climates avg 88-95 degrees. What is your average coolant temp. Mine is 235-245 would you say thats too hot on a long drive say an hr.?
Just seems high. Its been that way, no codes thrown good pressure good power just hotter than my Z was running with the same block almost same size cam just not stroked.
