Cleaning up brake calipers
Old 06-12-2011, 05:59 PM
Zerokube's Avatar
Default Cleaning up brake calipers
Need some info on how to properly clean up some used front brake calipers that i got. Like do i need to look out for anything in general? i plan on rebuilding them with the rebuild kit so can i just spray the hell out of them with brake cleaner and scrub them down? i plan on painting or polishing them.
Old 06-16-2011, 02:47 PM
c5z28's Avatar
Check to see if the bleeders are rusted or not, don't want that crud working it's way to your abs block. Careful with the products you clean/lube with. The rubber for brake systems will swell up with oil based products.
Old 06-17-2011, 10:50 AM
Zerokube's Avatar
I plan on buying the rebuild kits for them but was just wondering if i can just blast everything with brakeclean and sand it down a bit. like can i get the piston wet with the brakeclean?
Old 06-17-2011, 03:30 PM
Undertow74's Avatar
if you are rebuilding them like you say, i would blast them with some carb/brake cleaner and wire brush/steel wool, and then soak them in some grease lightning followed by some more steel wool fine grit sand paper and then go to town with the paint
