Power to Factory Fusebox?
Id like to use the factory 5.3 fusebox for my swap. Ive been following LT1Swap so far, but Im wondering how the factory sent battery power to the fusebox? How was it fused? Ill be running the fuel pump relay from the factory fusebox as well so I would like to be sure it is properly fused from the battery. I can see the Maxi fuses used by the factory, but can't find a good resource as to how they were wired up and fed power. Ive been using my multi-meter to try and make sense of it, but I would LOVE some to see how they were wired up from the factory.
What are all of the Maxi fuses for then? I have some of the diagrams for them, but they all state the function as battery power, and not what they connect into. I would think the power to the fuel pump would be fused at least?
