Tsunami cam Ls7 lifter - what length pushrods?!
Ended my night terribly... we could hear the pushrods falling when we turn the car off. we originally thought it was bad lifters.. im pissed i didnt think about that to begin with.. what size will put us in the right ballpark without buying a tester and wasting a week? we have 7.4 now
Update (6/22):
They are actually 7.425" Pushrods
Ordered Comp Cams Pro Magnum lifters
Install has begun
Update (6/22) PART 2:
Pulled the valve covers and found broken rockers!! Didn't even think about those, but it makes sense.. that was the last part that was stock
Update (6/22):
Install has begun
yea i was reading up that with stock ls1 lifters, tsp recommends 7.425.. which i just realized i have! the ls7 cup is .060 higher then ls1s - so id essentially need like 7.365 or so. With that said, these lifters must be DEADER then dead. I just ordered comp cam pro magnums 2nd day air. Gonna pull the engine apart over the weekend and pray the cam and pushrods are fine
LSxGuy widda 9sec Mustang
If you have rockers spitting the bearings out that quick, you have something wrong. Is this a dual spring kit? Did you use the valve spring seats and seals from the spring kit, or did you reuse the stock spring seat and seals?
I am unable to answer that question right now Joe. I can tell you this though - they were sitting all winter with no oil in the garage (both lifters and rockers). The LS7 lifters did in fact collapse as well. It was a giant mess in there. Luckily and amazingly theres little to no damage at all. New lifters and Rockers are going in today. I already have hardened pushrods and everything.
