dmracing
06-18-2011, 09:05 PM
Anyone thought of using the Fast 302000 for threr conversion comes with self learning ecm and harness for around $850.
Fahrenschnell
06-18-2011, 10:38 PM
That part number is for use with their TBI setup....It wont simply plug into a ls1. It would work if you use a carb intake and their whole setup and a MSD box.
The whole Fast setup is around $1800 and another $300 for the MSD. Not nearly as affordable.
dmracing
06-18-2011, 11:57 PM
You can use it. It for multi-port injection and you need to use fast part number 17604-8 for the injectors. Youll need to use a msd for the ignition.
