which lugnuts to get
i am about to swap in my s60 into my 02 camaro ss. i am keeping my factory chrome 17 inch rims. so my question is the rear has 1/2 studs (long), what are my options for lugs? would these work. http://www.summitracing.com/parts/SUM-7540026/ thanks for any help i can get...
Yes those lug nuts should work fine.If your factory wheels have the plastic caps over the lug nuts and you want to keep them you will need a oem style external thread lug nut in 1/2" size and then the bigger lug nut will need the larger size cap like GM trucks use.BTW the larger caps fit over the long studs on my 12bolt.
