What wheels with Moser 9"
What drag wheels/tires are you all running with the Moser 9". Was there any grinding involved?? How are your fender clearances? Is the car lowered or stock ride height??
Thanks
Scott
Thanks
Scott
i am running ET streets with mine............ 26" X11.5" on a 16" rim
in order to fit ET Drags i need to grind the calipers... since et drags only come in a 15" size for our application
alot of grinding due to not using the shims right.. or did you have to grind and use shims? cause im thinking abuot getting the welds as well. and the grinding only takes place on the rears right?? i polished my front calipers and really dont wanna grind on em.
S
S
Convo Pros .. no grinding, no spacers. BUT the bigest B/S is only 5" B/S. You can run 15x7.5 or 15x8.5 with some 26x10x15 ET Drags and they will not stick out to bad (due to the B/S). I have a Moser 12-bolt narrowed by 1.5" on each side. I fit 28x10.5x15 on 15x10 Convo Pros. No banging, no mods, no spacers, no grinding
David
David
