torque specs
Per the 99 GM Service Manual:
Differential Carrier Bearing Cap Bolt - 55 lb ft
Differential Drive Pinion Gear Setting Gauge Nut - 20 lb in
Differential Pinion Gear Shaft Lock Bolt - 27 lb ft
Differential Ring Gear Bolt - 89 lb ft
Rear Axle Housing Cover Bolt - 22 lb ft
Rear Axle Housing Drain Plug - 26 lb ft
Sensor Plug Mounting Bolt - 89 lb in
Wheel Bolt - 100 lb ft
Wheel Speed Sensor Mounting Plug - 89 lb in
