severely lowered guys
how do you jack your car? I'm lowering mine this weekend
back in the day, I had a slammed Mustang and I built some ramps out of 2"x12"s just to get the car high enough to get a low-profile jack under... I'm guessing I'll have to do the same thing again
any tips/advice appreciated
Trunion King
I use the same 2 x 4 method that everybody else seems to he using. Seems like the safest and most affordable way of doing it. It's really not that big of deal, I'm not sure why everybody thinks its such a pain.
I use 3-2x12s nailed together. The longest is 48", then 32", then 19". Then I have a 2x4 on top of that, that I use as a stop. Each 2x has an angle cut into it to make driving up on it easier. When I drive all the way up on the ramps, I can slide under the car (change oil, etc.) on cardboard, laid on the ground, but I can't fit when I'm on my creeper. Are they heavy and a pita...yes. But the wood was free so why not? It's all part of having a lowered car.
Buy a good jack that has a low point of 2.75". I can fit mine under just about any car out there with no issue. It only raises it 15" or so, but after you get it jacked up just a bit you can easily get the monster jack out and get it higher if need be. I bought my jack at harbor freight for ~$80. Aluminum too!
