Installing my new tubular k member a arm and coilovers!
Here are my pics of my tubular k member a arms coilovers and bear brakes. They look cool and they should perform great. When I get to the track I will let everyone know how they worked.
Its the performance automotive kit. Everything in the picture except the strutts came from PA. It bolted on so easily I could not believe it. PA was great help on the phone as well. Five stars for tech support and quality of the kit. I will let everyone know how well it works on the street and track as soon as I get the engine finished and installed.
Your right Kent! I think this kit is worth about 76lbs. I am also installing a liftoff fiberglass hood. I hope the weight savings makes a big difference. By the way SS, I was wrong. The brake setup came from Bear. My bad!
Sure. I have hooker super comps now. Full lenght. Mufflex 3in y-pipe and 4in after. Spin tech muffler. I had a buttload of clearance problems with the old k member. The new one is lower also. You can tell by the brake lines. I did not bend them yet. Where they are in the pic is where the old k member was.
I have the 700R4 right now but am going to put a th350 in later. I got a 383 with afr 210 heads and a ZZX cam form tpis. Its toped with a tpis miniram. This is coming off in favor of a super victor and 750hp series carb. Sorry, I'm going over to the dark side!
The K member was very light, but I am not sure. About 30 lbs maybe? sorry.
84, aarm, automotive, camaro, car, crossmember, drag, installing, kmember, mazda, member, performance, rx7, suspension, tubular
