'94 Camaro-Another evap solenod?
What is the solenoid that is under the ABS unit on the driver's side frame? It is on my '94 Camaro. Unable to get a picture right now and I have not located it in a search of websites. The ground wire from the ICM bolts right near it on the frame.
Same question
it does look like an evap solenoid but it is under the abs block on driver side. I wonder what it is too. Has like a red connector with wiring to it but not from the engine wiring harness. Also has vacuum lines to it. I'm thinking maybe something to a.i.r. But man I wonder what it is too.
