'94 Camaro-Another evap solenod?
Old 07-02-2011, 03:17 PM
Rich2279's Avatar
Default '94 Camaro-Another evap solenod?
What is the solenoid that is under the ABS unit on the driver's side frame? It is on my '94 Camaro. Unable to get a picture right now and I have not located it in a search of websites. The ground wire from the ICM bolts right near it on the frame.
Old 07-02-2011, 06:02 PM
RamAir95TA's Avatar
The only think electronic in that region is the cruise control box...but I'm not sure how you can confuse that with a solenoid. Post up a picture.
Old 07-02-2011, 10:30 PM
Rich2279's Avatar
I think it might be for the old air pump recall even though I have a '94 and the recall starts w/ '95.
Old 09-07-2013, 03:58 AM
adamc's Avatar
Default Same question
it does look like an evap solenoid but it is under the abs block on driver side. I wonder what it is too. Has like a red connector with wiring to it but not from the engine wiring harness. Also has vacuum lines to it. I'm thinking maybe something to a.i.r. But man I wonder what it is too.
Old 09-07-2013, 05:17 AM
RamAir95TA's Avatar
It's part of the AIR pump recall components.
Quick Reply: '94 Camaro-Another evap solenod?
