Cam Only Results...A Little Confused
I had my car dyno tuned yesterday at The Shop in Norwalk, CT and put down like 50 more hp than I was expecting...Am I underestimating my car or do these dyno's just read high? I mean, it's literally cam/exhaust and that's it.
They couldn't get an accurate AFR reading because my exhaust rattled too much for their probe and I don't have a wideband reader... Final pull was at 33* timing with zero knock.
I'll just copy my post from the cam only thread to make things easier...
1999 Trans Am M6
Comp Cams Custom Grind .610/.613 242/246 110 LSA
7.4" Pushrods
Patriot Gold Valve Springs
QTP Long Tube Headers & Catless Y-Pipe
SLP Loud Mouth II Catback
Lid
4.10s
Stock 853 heads
Stock LS1 Intake
Stock MAF/TB (descreened MAF)
Ambient temp of 85~ degrees.
Haha yes it says "2000 Pontaic" but they were just taking the info off the computer, it's got a 2000 pcm...
http://www.youtube.com/watch?v=x_HGIHlKBpg
1999 Trans Am M6
7.4" Pushrods
Lid
4.10s
Stock 853 heads
Stock LS1 Intake
As long if it got a good tune wouldn't stress it. But I would have asked the tuner that seems inflated .. but it doesn't matter just wait for a dyno day on a diff dyno see what it throws down
Yeah I'm not worried or care that much, I was just wondering if that type of dyno read high or whatever. That number is going to change regardless, it's no longer going to be a cam only car soon...
Is it uncorrected (STD)?
I would be more concerned about the lack of AFR and 33* myself. How do you even know if its tuned correctly and safe to drive without risking #7?
Personally I would seek out another tuner. Take it up and see Don at Slowhawk Performance. He will tune it so it won't detonate on the street.
Yea no way you're making that power. Just throw the sheet up on Facebook for bragging rights but it's not right. Traditionally Dyno Dynamics read the lowest but they're also the easiest dynos to manipulate. A couple of clicks and it goes from low to whatever you want it to be at.
A small example, there's a local import shop around here. Obviously won't name any names but they have a Dyno Dynamics. When they first got it they had the stock calibration on it for the longest. This dyno was known to put down low numbers. My 100 shot+exhaust 02 GT put down 306 whp on it but it ran strong at the track. You'd expect 330-340 whp on a DJ.
Fast forward a few years, some people leave the shop and others come in. Well now their Dyno Dynamics is a joke. You see incredibly impossible numbers coming out. Cars that should be making 180 whp roll out with 240+ dyno sheets. On top of that you see these cars run other people with "less" power or their trap speeds at the track and they're nowhere near their claims lol.
