Tire pressure sensor not working
I took off the wheels to get new tires and for some reason the rear driver side tire dosnt even show a 0 reading. All it shows it the 3 lines going across. Can somebody help?? Thanks
How do you think the RF signal is sent by the sensor inside your wheel? They need power to send the value to the car to put that number on your dash...
they are activated by pressure CHANGE, hence the calibration procedure for your car to pick up the RF signal...
(same as your key fob... which also has a battery )
Typical TPMS sensor battery lasts 7 or so years.
