2002 Camaro SOM 6spd 43k original miles 600+whp Lots of pics
Year: 2002
Make: Chevrolet
Model: Camaro
Price: $0
Mileage: 43788
Private or Dealer Listing: Private Listing
Location (State): OH
Color: Orange
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
-monster level 3 clutch (~7000 miles)
-new clutch slave at time of clutch
-tick clutch master cylinder
-D&D T56 viper build (less than 5000 miles)
-Remote bleader
-Quick time blow proof bell housing
-PST 1200hp 3.5in Aluminum Drive Shaft
-Pro 5.0 shifter
-Poly Trans mount
-Original Stock bottom 346 ls6 with Katech rod bolts and pistons fly cut .100" for valve clearence
-T.E.A. ported trick flow 215 heads milled to 58cc (less than 1000 miles)
-comp forged one piece push rods
-cometic .040" head gaskets
-Pat G custom ground cam 239/243 .624"/.624" 113+3 LSA
-texas speed ported ls6 oil pump
-ARP head bolts
-ls2 timing chain
-new cam and cranks sprockets
-Morel Hydraulic Lifters Link Bar Setup
-Yella Terra Ultralite Roller Rockers
-katech rod bolts
-kooks Stainless 1 7/8-2" long tubes with 3.5" collectors
-Kooks stainless 3.5 to 4" Y
-QTP Stainless 4" cutout pipe
-DMH 4" electric cutout
-Magnaflow cat back
-Fast 102 ported by tony mamo
-Nick Williams 102 throttle body
-mototron 60lb injectors
-LS2 fuel rail
-LS2 fuel rail adapter set
-Fast toys 104mm air lid
-Custom bellows for larger air lid
-K&N air filter
-Katech belt tensioner
-ASP underdrive pulley
-ARP balancer bolt
-racetronix fuel pump and hot wire kit
-dyno tune (Tracey Scott of Cincy Speed)
-poly motor mounts
-NX nitrous kit (shark nozzle system good to 250hp)
-Harris speed works nitrous bottle heater
-Harris speed works nitrous botle brackets
-Harris speed works nitrous purge kit
-nitrous spare tire bottle mount
-zex remote bottle opener
-Innovate digital nitrous gauge
-Harris speed works nitrous ash tray switch panel
-Custom remote opener/nitrous gauge panel in console
-Weld RTS racing wheels
-Mickey Thompson 28x10.5 slicks (only two track passes)
-Mickey Thompson Tubes
-wheel screw kit
-Spohn pro series chrome moly torque arm
-Spohn chrome moly adjustable panhard
-spohn lca relocation brackets
-Spohn chromemoly weld in subframe connectors
-umi adjustable lca's poly one end rod end the other
-Strange single adjustable rear shocks
-Eibach sportline lowering springs
-slp roll control
-Autometer dual pillar pod
-Innovate wideband LC-1
-Autometer electronic sport comp fuel pressure gauge
-Moser 12 bolt gurdled aluminum cover 4 channel abs, auburn posi, 30 spline moser axles, 4.10 gears
-ARP wheel studs
-Hawk brake pads
I have reciepts for most all parts on the car. Also have the original window sticker. Car has scene nothing but mobil one full synthetic oil.
Here's a link for more photos of the car
http://s96.photobucket.com/albums/l193/gearheadls1/
SOLD
DYNO VIDEO
