Track results inside w/the new setup, but something isnt right. Please help!
I converted from a 6 speed to a 200-4R. I have the TCI 29.1 SFI approved flexplate, Yank SS4000, fully built 200-4R by Mike Kurtz at Century Transmission, stock 10 bolt w/ 3.42s, most bolt ons, C2 cam, Spohn chromoly suspension-LCAs, PHB, TA, rear swaybar, SFCs, Hals in a 4 corners w/new R series in the front, Denny's nitrous ready shaft, Bogarts, and ET Streets. Weight of car w/me in it is 3470 lbs. Here were the results:
Best:
60 ft. 1.62
1/8 7.32/94.99
1/4 11.52/114.34
Whats wrong...its seems that theres something going on in the top end. It felt kinda weak towards the end of the track. Any ideas, suggestions, cures, etc.? Thanks.
Best:
60 ft. 1.62
1/8 7.32/94.99
1/4 11.52/114.34
Everyone so far has commented on my 60 ft...Im almost positive that it didnt spin. It felt really good leaving the line, how noticeable will slight spin be because maybe I missed it. I thought that 1.6s were good, but it seems that everyone is leaning towards 1.5s. That was just my first night out, but as I was looking at my slips, I think the car has 1.59 in it, but 1.55 may be hard. Do you think the SS series hits hard enough for a mid 1.5 60 ft.? Also, I think the car has 11.4 in it with the way it sits, but who knows...if I get this problem fixed, I might be able to hit 11.3. What do you think is wrong with the car because it seems weak on the top end? Ive been told that the mph should be a little higher. I hope to get this fixed for next Friday. Thanks.
Looks to me that your getting some KR on the topend of the track and slowing you down so i would Atap it to make sure or your timing is not getting lower as your climbing in the RPMs.
With that cam you need atleast some 3.73s for it to start getting into the power band at the last few hundred feet of the track and if your running 11.5 ET streets with 3.42s then your crossing the traps with a gear ratio lower than 3.23 IMO.
Originally Posted by NVMySS
How does the width of the tire affect the gearing? Its a 26" tall tire, which isnt much taller than the 285/40/17s I ran.
A 95mph 1/8th gets me around 119 in the 1/4 but my 60fts. are 1.51s-1.52s and my car is 100lbs. lighter.
Also dont for get that 200r4s only have a 2.74 first gear and not a 3.06 like the 4l60e. If you would have a 4l60e and 3.08 gears you have more gear in first then a 200r4 with 3.42s.
I also agree that something is going on the top end(ie.. KR, fuel problem). If your trapping 94-95mph in the 1/8 you should be trapping alot higher in the 1/4 than 114.
Well Id like to see if there are some problems with the car, but MTI wants to charge me $75 to do so. I bought my tuning in January of '03 and that was way before the deadline on those who had to start paying $75 for each retune. Im hoping to find someone in my area who can Autotap my car to see whats going on. Its a shame that MTI cant take a half an hour to help me out. Ive never ran into this before until the new policy came about. I never abused the lifetime policy, so I dont understand why the good guys get punished for it.
