HKE LSX 434 long block
I have an LSX 434 w/TFS 245 heads on top. 6 bolt option, Callies Compstar internals, Wiseco custom pistons, Custom pins, GFX rings, Fed Mogul and ACL coated race bearings, 251 / 263 / 113+3 cam, Double roller timing set, Morel link bar lifters, Melling Hv oil pump,
You need your oil pan and valley pan, all other covers are included. It has an LS2 timing cover
In crate ready to go.....
$13750 plus delivery. It has a 24x reluctor but it can be changed if need be for a few hundred, or you buy the converter box if you have a call that uses a 58x. We can also swap the cam if you want. This engine is built to handle a lot of nitrous if a person wanted to run it.
