ATI Crank Pin HELP
ATI Crank Pin HELP
Pinning my crankshaft with ATI pinning kit. Drilled and reamed and pin doesn't want to go in enough. Protruding .29" now and need to get to .093" is something wrong, I hate pounding on the crankshaft. Pin is .50" long.
I can't get the pin out now. Okay to grind it down to .093? .22" in the crank.
.22" into crank, pin is .50" long, .28" protruding from crank. Pounded it in. Used vise grips trying to pull it out, no luck. I think grinding it down is my only option. No way to push out from inside. Thanks.
