heads/cam change ?
Ok thank you.
Will these bolts work?
http://www.summitracing.com/parts/NAL-12498545/
It says they are 5mm longer than 2004-2007 bolts. I am replacing my 241 heads with 243 heads on my 2004 LS1 GTO.
Or will i need these bolts.
http://www.summitracing.com/parts/NAL-17800568/
It says they are 5mm shorter than 1997-2003 bolts. So im assumeing since i have a 2004 LS1 i should get these right?
