anyone ever use this intake mani?
http://www.ws6project.com/user_stor/...take-manifold/
Was wonderin if any one has personally used this or have seen dyno charts of stock ls1 intake mani then this one, assuming it would be at least equall to or better then ls6 mani, looking at going FI in future too, any input is appritiated
its a good intake ,but I bet you can find 1 like it used in the used parts section for cheaper.a used BBK intake will work also.buy a TB to match the intake opening size if you don,t port it larger.
i have this intake as well. What i liked about it is the fact that the bottom has a plate that can be removed for extensive port work..Plus if you plan on FI, i like the idea of having a METAL intake instead of composite PLASTIC...
sorry no dyno numbers.....
