think my flexplate is F&%KED??
Old 07-09-2011, 12:57 PM
96RamAirTA's Avatar
Default think my flexplate is F&%KED??
well replaced the starter started the car up and made the worst noise ive ever heard kinda like a clunking and belt squelling sound from idle up does this sound right? if so which flexplate should i get ive only seen the one from TCI for ls1s that and i think ill get my stall reflashed up from 3200 to 4000 will i need to do any retuning on my car if i do that or should i just leave it be? thanks
Old 07-09-2011, 02:43 PM
BrianC98Z28's Avatar
SFI from yank is like $75 vs $210 for the tci, but what makes you believe its the flexplate?? is the starter ring ate up or ive actually had one come loose before.
Old 07-10-2011, 01:52 AM
96RamAirTA's Avatar
no the starter ring wasnt ate up and its not loose but i did have a blot bolt that holds it down. ill try and get a video of it tommorow for you guys
