Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
1969 Camaro trans crossmember removal question
Old 07-10-2011, 05:58 PM
camaro_five0's Avatar
Default 1969 Camaro trans crossmember removal question
Do I have to drop the frame from the body to remove the transmission cross member from a '69 Camaro? I have the bolts out but cannot slide the cross member out because of body clearance (I cannot twist or shimmy it out).
Old 07-10-2011, 06:03 PM
BlueZ's Avatar
Big Hammer.
Make sure trans weight not on it.
Also if body bushings wore out, hammer it out from one side.
Old 07-10-2011, 08:57 PM
Ok, that is what I was thinking. I started beating on it with a hammer, but stopped halfway through since I didn't want to screw anything up. I'm doing a trans swap, so I'm going to scrap the old cross member anyway. Thanks for the feedback!
Old 07-25-2011, 08:26 PM
Timmy P's Avatar
Slide the passenger side forward. There is a little indention on the floor. Then slide the driverside back and you can work it out. I do it all the time on many customers cars.
Quick Reply: 1969 Camaro trans crossmember removal question
