1969 Camaro trans crossmember removal question
Do I have to drop the frame from the body to remove the transmission cross member from a '69 Camaro? I have the bolts out but cannot slide the cross member out because of body clearance (I cannot twist or shimmy it out).
Ok, that is what I was thinking. I started beating on it with a hammer, but stopped halfway through since I didn't want to screw anything up. I'm doing a trans swap, so I'm going to scrap the old cross member anyway. Thanks for the feedback!
