Western Members CA, AZ, NV, UT, CO, NM, HI
Need Help!!!
Old 07-12-2011, 01:07 AM
Mr.z/28's Avatar
Default Need Help!!!
So today my car started acting up a little bit. When Im driving normally and hit a small bump, or step on it, These lights start flashing, and then the air bag light stays flashing for about 4 or 5 blinks, then stops, and it happens again. I happen to flash my high beams today and it turned off on me. Whats going on? I need your help.
View My Video
sorry for the crappy vid, but I hope its enough for you to understand the problem, if you know it. thank you.
Old 07-12-2011, 01:42 AM
0235SS's Avatar
View My Video
ether its your alternator ready to give out , or your BCM taking a dump theres a fix in case u wanna double check your BCM(before you do, have u had any problems with your stereo randomly turning off or any other electrical issues?)
Old 07-12-2011, 01:45 AM
mannyman84's Avatar
Check your charging system, battery, connections. Is your battery tied down as it should? Any major work done lately?
Old 07-12-2011, 04:57 PM
Mr.z/28's Avatar
Stereo randomly turns off, yes, and when it does, it goes on and off for a few seconds then comes back again and works good, but after a while it happens again. Yesterday was the first day the lights came on, and air bag light flashing for a few seconds. I woke up today at 5am to go to work, it gave me a low low idle, then it recovered and when I put it in reverse it turned off. turned it back on again and drove to work and when I got there I disconnected the battery for an 1hr or 2. I went out to lunch, it turned on fine, drove fine, thought problem solved, guess not. Right when leaving work I turn it on, and everything went out. no lights, no cranking, nothing. 10 seconds later it turns on. Im furious.
Old 07-12-2011, 05:00 PM
Mr.z/28's Avatar
Battery is tied down. no major work. Its a stock DD for work.
Old 07-12-2011, 07:00 PM
0235SS's Avatar
ok its kinda hard to see where the problem is because of the low idle, ether way try this
https://ls1tech.com/forums/general-l...ems-fix-4.html
Old 07-12-2011, 07:32 PM
Raptor_WS6's Avatar
you may be furious
but are you fast and furious also
Old 07-12-2011, 10:31 PM
Mr.z/28's Avatar
Originally Posted by Raptor_WS6
you may be furious
lol
Old 07-13-2011, 05:46 AM
Mr.z/28's Avatar
so would anyone be willing to fix my BCM for $$. Im on budget.
