What throttle cable do I need ? Fast 102 TB and converting to NON Traction Control.
Old 07-13-2011, 11:44 AM
DETROIT_AREA_00_SS's Avatar
Default What throttle cable do I need ? Fast 102 TB and converting to NON Traction Control.
Dealer tells me part# 12565559 but it is NON returnable if it is NOT the right part since it doesn't match my VIN number (car came with TC).
I have a FAST 102mm TB and want to convert to NO cruise, and NO Traction control / abs.
Old 07-13-2011, 11:58 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
12565559 is for the 98-99 F-body without TCS.
12565560 is for the 00-02 F-body without TCS.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 07-13-2011, 04:19 PM
The dealer said the difference is at the end by the throttle body. Is that true? If so, what is the difference?
Old 07-13-2011, 04:21 PM
Yes, the difference in year model was the length of the cable. This is why on the aftermarket TB's they have multiple holes for that little ball-end to go into...so that the aftermarket TB manufacturers do not have to make multiple TB's to fit different year models.
__________________
Old 07-13-2011, 04:24 PM
Thanks!
Old 07-14-2011, 09:31 AM
Anytime! Sorry I couldn't be of more help on that stuff you PM'd me about
__________________
Old 02-24-2013, 06:04 PM
sickspeedmaro's Avatar
Default Throttle cable
I also have a 1999 z28 camaro with tcs and 102 fast tb will 12565559 cable work i want to eliminate my tcs but want to keep my abs what should i do will deleting the tcs eliminate my abs as well if not could i get a cable with tcs and adjust it and keep my tcs so i dont lose my abs if so what is the part number for the cable with tcs with the adjuster made on the cable.
Quick Reply: What throttle cable do I need ? Fast 102 TB and converting to NON Traction Control.
