What throttle cable do I need ? Fast 102 TB and converting to NON Traction Control.
Dealer tells me part# 12565559 but it is NON returnable if it is NOT the right part since it doesn't match my VIN number (car came with TC).
I have a FAST 102mm TB and want to convert to NO cruise, and NO Traction control / abs.
LS1Tech Premium Sponsor
12565559 is for the 98-99 F-body without TCS.
12565560 is for the 00-02 F-body without TCS.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Yes, the difference in year model was the length of the cable. This is why on the aftermarket TB's they have multiple holes for that little ball-end to go into...so that the aftermarket TB manufacturers do not have to make multiple TB's to fit different year models.
__________________
Anytime! Sorry I couldn't be of more help on that stuff you PM'd me about
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
I also have a 1999 z28 camaro with tcs and 102 fast tb will 12565559 cable work i want to eliminate my tcs but want to keep my abs what should i do will deleting the tcs eliminate my abs as well if not could i get a cable with tcs and adjust it and keep my tcs so i dont lose my abs if so what is the part number for the cable with tcs with the adjuster made on the cable.
