General LSX Automobile Discussion Non-technical LSX related topics.
Would a bad window motor cause this?
Old 07-13-2011, 07:12 PM
Tan327's Avatar
Default Would a bad window motor cause this?
My drivers side window will only go down sometimes, but when it does go down/up it is not slow. I can hear a click coming from inside the door when I press the switch and it doesn't go down. However my passenger side window motor is dying, but it goes up/down every time, just slowly.
I thought this was an issue with the BCM, because it would only do this when the radio went out, but I think* I successfully did the solder trick on the BCM and fixed the radio, drivers window won't go down now. I have tried 2 different window switches too. Any help would be greatly appreciated!
Old 07-14-2011, 09:31 PM
TankTheTurtle's Avatar
when you say a click, do you mean a mechanical or electrical click?
something similar happened with mine, something shifted inside the door which made the gear on the motor slip off of the gear on the mechanism.
Old 07-14-2011, 09:34 PM
Tan327's Avatar
Electrical. Thanks for the reply but think I'm going to do the manual window swap and be done with it!
