Would a bad window motor cause this?
My drivers side window will only go down sometimes, but when it does go down/up it is not slow. I can hear a click coming from inside the door when I press the switch and it doesn't go down. However my passenger side window motor is dying, but it goes up/down every time, just slowly.
I thought this was an issue with the BCM, because it would only do this when the radio went out, but I think* I successfully did the solder trick on the BCM and fixed the radio, drivers window won't go down now. I have tried 2 different window switches too. Any help would be greatly appreciated!
when you say a click, do you mean a mechanical or electrical click?
something similar happened with mine, something shifted inside the door which made the gear on the motor slip off of the gear on the mechanism.
