right side o2 stuck at 1.092 volts
Old 07-15-2011, 01:43 PM
Chris Smith's Avatar
Default right side o2 stuck at 1.092 volts
I have replaced this o2 sensor twice. I have tested the harness per the tech manual to test for bad pcm/ wiring and it check out good. It will read. 450 untill I ground the threads of the sensor to frame. ( I did that to make sure it wasn't actually sniffing raw fuel in the header) when I ground it it immediately spikes to 1.092 volts. Any suggestions?
Old 07-16-2011, 09:53 AM
I have checked around the headers and there are no burnt wires.
Old 07-16-2011, 01:35 PM
Big Al's Avatar
If I had to deal with this I'd disconnect the connector and hook a digital voltmeter to the sensor. Then see what's really going on.
http://shbox.com/1/HO2S_connector.jpg
Al 95 Z28
