lt1 cutting fuel issue
Old 07-20-2011, 12:22 AM
Ziegele's Avatar
Default lt1 cutting fuel issue
hey guys, i have a 93 trans am and when i drive it around for awhile and it gets warm it'll cut fuel and then not start again for anywhere between 5 min to 2 hours, if anyone has had this problem i'd really appreciate it if you could help me out, thanks.
Old 07-20-2011, 05:36 AM
RamAir95TA's Avatar
How do you know that it is cutting fuel and not something ignition-related? Just curious how you ruled out the ignition system. I ask because the most common causes of a no-start-when-warm condition is heatsoak of some failing electrical component, like the ICM, coil, opti, etc.
Old 07-22-2011, 12:19 AM
Ziegele's Avatar
i thought it was at first so it has a brand new ignition, new opti, icm and coil. and when its dead if you squirt brake cleaner in the throttle body it'll start right up.
